www.formulabrakeusa.com/blog/index.html www.formulabrakeusa.com/…ructions.pdf
// Your Formula Oro Disc brake system may be the subject of a safety recall. If your bike has a Formula Oro disc brake system installed, STOP RIDING YOUR BIKE until you determine whether your brakes are part of this recall.
The set screw which secures the pin which attaches the brake lever to the master cylinder may come loose. If these set screws come loose, your brake levers may separate from the brake, rendering the brakes inoperable, and you could lose control of your bike and fall.
Check the serial number of your brakes at the brake lever. Brakes with a serial number lower than 295237 are included. If you have an affected brake set, bring it to the bicycle dealer where you purchased the brakes for inspection and repair. //
// Q: Which Brakes are affected by the recall?
* All Oro brakes manufactured prior to July, 2007.
* All Oro brakes with master cylinder serial numbers lower than
295237.
* Some 2005–2006 Oro Puro brakes are not affected, as the brake lever pin is
secured with a clip rather than a set screw. If your Oro Puro brakes lack the
set screw shown in the repair instructions, they may not be affected. Please
have your dealer inspect the levers! //
